cancel
Showing results for
Search instead for
Did you mean:
aasalem
Level 7
Trace-Route not ending Right
0 Kudos
ram.esakky
Level 10
Re: Trace-Route not ending Right
I have informed the development team with the issue, someone should contact you soon with a remedy. Thank you
-Ram Esakky
0 Kudos
aasalem
Level 7
Thanks, We still doing the same thing, however,  what am trying to understand is: what may be the reason that CQ Trace ends one and some time two hubs after me.
Traceroute, Visual Trace Route, IP Trace, IP Address Route Location 2013-10-17 20-07-11.png
0 Kudos
aasalem
Level 7
This yet keeps happening from time to time.
CQ-Albany-screenshot-cqcounter.com 2017-01-14 16-31-42.pngWorkspaces_032.png
Both showing wrong location. That is coupled with trace-route link arrives undefined.
Delivered-To: xxxxxxxx@gmail.com
Received: by 10.223.166.70 with SMTP id k64csp1685453wrc;
  Sun, 24 Sep 2017 10:00:24 -0700 (PDT)
X-Google-Smtp-Source: AOwi7QAwuOKbeIerIhQgVZvpD6JsBCmSg79gmKudMnwU7nv2shpUad6qko7dUfPK04iBYIZ6z26A
X-Received: by 10.99.109.3 with SMTP id i3mr5166409pgc.233.1506272424213;
ARC-Seal: i=1; a=rsa-sha256; t=1506272424; cv=none;
  d=google.com; s=arc-20160816;
  b=MmPFAMAntiCGQwjtKGRPMktcmSMr6H8DiDKBxw8Ownpt5hsSrs2KYBlIwhsmVgLQR1
  Kx+kP8+bgx1hnN8VE4JiY+i8yfWe/3UnB56iFLiwxc40fNDkUZQ0nZ4LzGCnlzNLVE42
  +l7QuU7+GplTVKu4ZJWoVAK3cgLUUFIwcL8xUSJtjYAj7YF7WwocxPbrhzlb407oWuI9
  xkjEg8j4Z4jIfm7L8a7aXDWdc90fOTSlqeNIxMTfUCF+RX8RZ931DX8fzNJE/z31ZC6W
  xjYo8mNkCfNMfO3thB9Zep79gECXT98u/LplWF0JvJNxxYILUyutub1XZIH5Y5yIhm3n
  rxoA==
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=google.com; s=arc-20160816;
  h=mime-version:message-id:reply-to:from:date:subject:to
  :arc-authentication-results;
  bh=3Hu/bf37c+tgsCvZLhpnMxOR7gwWKQmgCqG2zpxRDNI=;
  b=r8aAo+gb7Z1RpxBQNtm9/qATmvFd0EQSEb49TgGcnrR0Xp4iJkJB60VfzoHPIT16FW
  Zwi6mo2+Tk+rkczIHabTEf0tjrDZhSluhy/vRzTEGyc9e3Djxc/bw1o2s/mv+EzoMuNX
  YLTtNQosj7lcCfQx+sUAJiIEW633SESLRL09Zb2FLHPDGzWCWUNckk/sHXsuMgmRC9bE
  3kyMXOhJmbd+EH3XlGTIpbOrKJhP735PLaWwRJqaRXtCp9yzA29VP2ZVGhiTLy6ahgir
  hC9Pigq7R7gBiEOq5rrw2JbSP+gfEF3jNH581gpYaNuiEbgAG6p5pYeRveJ8mw70Y25s
  dKjg==
ARC-Authentication-Results: i=1; mx.google.com;
  spf=fail (google.com: domain of prvs=4336a85a2=no_reply@dnsstuff.com does not designate 74.115.14.109 as permitted sender) smtp.mailfrom=prvs=4336a85a2=no_reply@dnsstuff.com
Return-Path: <prvs=4336a85a2=no_reply@dnsstuff.com>
Received: from DENCIM02.solarwinds.com (dencim02.solarwinds.net. [74.115.14.109])
  by mx.google.com with ESMTPS id r6si2766267pfb.250.2017.09.24.10.00.22
  for <xxxxxxxx@gmail.com>
  (version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128);
  Sun, 24 Sep 2017 10:00:23 -0700 (PDT)
Received-SPF: fail (google.com: domain of prvs=4336a85a2=no_reply@dnsstuff.com does not designate 74.115.14.109 as permitted sender) client-ip=74.115.14.109;
Authentication-Results: mx.google.com;
X-IronPort-AV: E=Sophos;i="5.42,433,1500962400";
  d="scan'208";a="10454437"
Received: from swmailserver.dmz.local (HELO ADFSMTP01.dmz.local) ([10.10.10.28])
  by DENCIM02.solarwinds.com with ESMTP; 24 Sep 2017 11:00:20 -0600
Received: from adf-web-11.dmz.local ([10.10.11.200])
  by ADFSMTP01.dmz.local with ESMTP; 24 Sep 2017 12:00:20 -0500
Received: by adf-web-11.dmz.local (Postfix, from userid 48) id 8DC46A5226; Sun, 24 Sep 2017 12:00:20 -0500 (CDT)
Subject: xxxxxxxx@gmail.com shared their DNSstuff test results with you!
X-PHP-Originating-Script: 0:class.phpmailer.php
Date: Sun, 24 Sep 2017 12:00:20 -0500
Reply-to: xxxxxxxx@gmail.com
Message-ID: <0a879a3bba3d39f5120f9ad48d5ff15d@www.dnsstuff.com>
X-Priority: 3
X-Mailer: PHPMailer 5.1 (phpmailer.sourceforge.net)
MIME-Version: 1.0
Content-Type: multipart/alternative; boundary="b1_0a879a3bba3d39f5120f9ad48d5ff15d"
--b1_0a879a3bba3d39f5120f9ad48d5ff15d
Content-Type: text/plain; charset = "iso-8859-1"
Content-Transfer-Encoding: 8bit
| undefined
Content-Type: text/html; charset = "iso-8859-1"
&#160;|&#160;undefined
--b1_0a879a3bba3d39f5120f9ad48d5ff15d--
0 Kudos
