cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
Shutdown Interface using Powershell or Python or NCM?
Hello,
Is there a way to shutdown an interface after a certain amount of time being down? I'm trying to create an alert that will email stating it is down (this part works) then the escalation portion will then run an ncm script or external script to shutdown the interface. Is this possible?
0 Kudos
1 Reply
Level 13
If I understand your intention correctly, you may want to try invoking the Unmanage verb on Orion.NPM.Interfaces
http://solarwinds.github.io/OrionSDK/2019.4/schema/Orion.NPM.Interfaces.html
There are some examples of invoking that verb via PowerShell and the REST API in this thread:
Unmanage Interface via Script
