SQL Help, Alert History filtered by custom property
I could use some assistance on this.  I'm pretty rusty on doing anything SQL, and have never really done joins, and I don't have much experience manually digging around the SolarWinds database.  I'm looking to create a report that shows the last 30 (or maybe 90?) days of alerts with for a specific client.  We have a custom property for the client name.  I was able to get a query to pull most of what I need from the Alert History View, but I want the report to show the time the alert triggered, when it was acknowledged, and ideally when it reset.  That's where I'm getting stuck.  That info isn't in the AlertHistoryView so I'm assuming I need to another table.  The AlertActive table seems to have the data I need and the AlertActiveID appears to link the two but I'm apparently missing something.
SELECT ah.EventTypeWord, ah.Message, ah.TimeStamp, ah.RelatedNodeCaption FROM AlertHistoryView ah
INNER JOIN NodesCustomProperties ncp
ON ah.RelatedNodeID =ncp.NodeID
WHERE ncp.CustomerName = 'Client Name' AND ah.EventTypeWord = 'Triggered' AND ah.TimeStamp >= DATEADD(month,-1,GETDATE())
ORDER BY ah.TimeStamp
But when I add a second join, I get no results.
INNER JOIN AlertActive aa
ON ah.AlertActiveID=aa.AlertActiveID
If I manually search for a specific AlertActiveID number in both tables, I get the data I would expect, so what am I not understanding about doing multiple joins?  Or am I completely approaching this the wrong way entirely?
  • Use this in a custom query resource in the web console, sounds like it has everything you are looking for
    --report on alerts triggered
    select ac.Name
    ,ah.Message
    ,'/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:'+ToString(AlertObjectID) as [_linkfor_Name]
    ,EntityCaption as [Trigger Object]
    ,EntityDetailsUrl as [_linkfor_Trigger Object]
    ,case
    WHEN RelatedNodeCaption=EntityCaption THEN 'Self'
    When RelatedNodeCaption!=EntityCaption THEN RelatedNodeCaption
    End as [Parent Node]
    ,RelatedNodeDetailsUrl as [_linkfor_Parent Node]
    ,'/Orion/images/StatusIcons/Small-' + p.StatusIcon AS [_IconFor_Parent Node]
    ,tostring(tolocal(ah.TimeStamp)) as [Trigger Time]
    ,case when ack.timestamp is null then 'N/A'
    else tostring(minutediff(ah.TimeStamp,ack.timestamp))
    end as [Minutes Until Acknowledged]
    ,ack.Message as [Note]
    ,case when reset.timestamp is null then 'N/A'
    else tostring(minutediff(ah.TimeStamp,reset.timestamp))
    end as [Minutes Until Reset]
    FROM Orion.AlertHistory ah
    left join Orion.AlertObjects ao on ao.alertobjectid=ah.alertobjectid
    left join Orion.AlertConfigurations ac on ac.alertid=ao.alertid
    left join Orion.Actions a on a.actionid=ah.actionid
    left join Orion.Nodes p on p.nodeid=RelatedNodeID
    left join (select timestamp, AlertActiveID, AlertObjectID,message from orion.alerthistory ah where eventtype=2) ack on ack.alertactiveid=ah.AlertActiveID and ack.alertobjectid=ah.AlertObjectID
    left join (select timestamp, AlertActiveID, AlertObjectID from orion.alerthistory ah where eventtype=1) reset on reset.alertactiveid=ah.AlertActiveID and reset.alertobjectid=ah.AlertObjectID
    WHERE
    daydiff(ah.timestamp,GETUTCDATE())<30
    and ah.eventtype=0
    --and (ac.Name like '%${SEARCH_STRING}%' or EntityCaption like '%${SEARCH_STRING}%' or RelatedNodeCaption like '%${SEARCH_STRING}%')
    --and p.customproperties.customername like 'whatever'
    order by ah.timestamp desc
  • That looks to be perfect.  Very much appreciated!
  • I found this very helpful. BUT I  am stumped trying to add data to the report with fields from our Custom Properties.
    I see this part:
    and I understand that if my Custom Property field name is "client" I would use
    p.customproperties.client
    Or if the field was named "ad_domain" I would use
    p.customproperties.ad_domain
    I just don't see where I would add that SWQL to the report to include "ad_domain" as an item in this report.
    My goal
    Include ad domain then Group results by p.customproperties.ad_domain then ORDER by p.customproperties.client, then by ah.timestamp desc
    Any assistance is appreciated!
  • Just add your p.customproperties.ad_domain to the select section, and then to the order by before the timestamp
  • Hi,
    Thank you for posting the query this is helpful.  I just want to add one more thing but can't find the ac.? or where to look and where to add this to the query. "Object that triggered this alert"
    any help is appreciate it.
    Thanks in Advance,
    Cheers,
    Lester C
