Need simple SWQL query help!
Would like to use swql to return the following:
NodeID, NodeName, followed by all custom properties that are not NULL or BLANK.
Has anyone done this with SWQL?   Reason for SWQL is so that I can create a custom SWQL resource with a search bar as I need to be able to query large sets of nodes with similar naming conventions.
Please assist if possible.
  • 1) You have to specify each custom property you want to display.  I mean there is almost always a way... but no, that would be a horrific swql.
    2) the search swql is a complete and independent query.
    So the custom SWQL would look like:
    select n.NodeID, n.NodeName, n.CustomProperties.something, n.CustomProperties.somethingelse, n.CustomProperties.theotherthing
    from Orion.Nodes n
    and the search SWQL query would look like:
    from Orion.Nodes n
    where n.nodename like '%${SEARCH_STRING}%'
    And you can decide if you want to have the %'s around the search string or not.
  • So I tried
    Select
          n.NodeID,
    From
         Orion.nodes n
    And I get an error message
    No Viable alternative at input 'FROM' in Select clause.
    I really just dont get this SWQL - whats up with the n after Orion.Nodes
    I see in the SWQL studio that there is another table called Orion.NodesCustomProperties I am afraid I need a Join command.   I can do this in SQL but not SWQL.
  • SWQL has almost the same conventions as T-SQL because ultimately it gets converted by the info service into T-sql.
    You had an error because you put an extra comma after the nodeid and didn't specify any other columns.
    The n after nodes is just an alias for the table name.
    You can inner and left join in SWQL the same as SQL, but if you are looking in SWQL studio you will notice many tables have a list of values with a little chain link icon next to them, those are joins that are already completed for you by the devs, so to get from nodes to nodescustomproperties all you need to do is
    select n.nodeid, n.customproperties.yourpropertyname
    from orion.nodes n
