cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 8
Re: Need a custom SQL report for discovery results
Hi there!
I'd like to bump this post once again as I am searching for the same information...
Maybe the Solarwinds tech staff could hook in and reveal how the new/changed/as-is information is calculated from the tables
Kind regards, Jörg
0 Kudos
Highlighted
Level 7
+1
It would be great to have a solution for this.
0 Kudos
Highlighted
Level 9
Thanks for the report, this is the best thing I have found and this was a post from five years ago!  Has there been any new developments around a built in report for this capability?
0 Kudos
Highlighted
Level 9
is there a way to ignore any new discoveries that already been mark ignore  on this report ?
0 Kudos
Highlighted
Level 9
Select
DiscoveryProfiles.Name as Discovery_Name,
DiscoveredNodes.SysName as Node_Name,
Discoverednodes.IPAddress,
DiscoveryProfiles.EngineID as Poller,
DiscoveryProfiles.LastRun as LastRun
From DiscoveredNodes
Join DiscoveryProfiles on DiscoveredNodes.ProfileID = DiscoveryProfiles.ProfileID
Where IPAddress NOT IN (Select IP_Address from Nodes) AND
IPAddress Not in (Select IPAddress from NodeIPAddresses)
AND Sysname NOT IN (Select Caption from Nodes)
AND SysName NOT IN (Select DNS from Nodes)
AND IPAddress NOT IN (Select IPAddress from DiscoveryIgnoredNodes)
I was able ignore the ignore list on this report
0 Kudos
