cancel
Showing results for
Search instead for
Did you mean:
Create Post
Highlighted
Level 17
Re: Need a custom SQL report for discovery results
I could see that with the face we're joining on the nodes table.  Effectively I believe that anything in that query would be in the nodes table now that I think on it further.
Try:
Select
DiscoveryProfiles.Name as Discovery_Name,
DiscoveredNodes.Hostname as Node_Name,
DiscoveryProfiles.EngineID as Poller,
Engines.ServerName as PollerName,
DiscoveryProfiles.LastRun as LastRun
From DiscoveredNodes
Join DiscoveryProfiles on DiscoveredNodes.ProfileID = DiscoveryProfiles.ProfileID
Join Engines on DiscoveryProfiles.EngineID = Engines.EngineID
Where DiscoveredNodes.NodeID NOT IN (Select NodeID from Nodes)
0 Kudos
Highlighted
Level 12
Still seeing nodes that are have been added to the DB.
0 Kudos
Highlighted
Level 17
Select
0 Kudos
Highlighted
Level 12
Looks like the Where statement is not working, because I am still seeing nodes that HAVE been added to the database appear in this report. Are you able to test this SQL in your environment?
0 Kudos
Highlighted
Level 17
Turns out the nodeID wasn't what the whereclause needed.  Using sysname seems to have proven better results.
Select
DiscoveredNodes.SysName as Node_Name,
Where SysName not in (Select Caption from Nodes)
Feel free to make any other adjustments running this in your environment in order to fine tune to meet your needs.
0 Kudos
Highlighted
Level 17
Update:  Due to the changes and additions in NPM there are some other filters added in the WhereClause to ensure accuracy.
Select
Discoverednodes.IPAddress,
Where IPAddress NOT IN (Select IP_Address from Nodes) AND
IPAddress Not in (Select IPAddress from NodeIPAddresses)
AND Sysname NOT IN (Select Caption from Nodes)
AND SysName NOT IN (Select DNS from Nodes)
0 Kudos
Highlighted
Level 12
Now we seem to be getting somewhere. However, I found that the most recent iteration shows no nodes that are in the DB, but is missing some nodes that should be on the report. I found that if I delete the last two lines in the Where clause, the list of IPs in the report matches the list of FOUND nodes on the Scheduled Discovery Results tab. Does that make sense?
0 Kudos
Highlighted
Level 17
the last two lines are merely comparing the Sysname in the Discovered Nodes table to the Caption and DNS fields in the nodes table and ensuring it doesn't match either in order to show up in the report.
0 Kudos
Highlighted
Level 11
I haven't had a chance to look too deeply into this to confirm my thoughts of what each status means, but I think you may want to take a look at the discoverednetobjectstatuses table in order to determine whether it is newly found or changed.  Guessing at it, it looks like a status 32 is either ignored or not added and not in the system but is a newly found node.  A status 33 makes me think that indicates a change to the Node and a statuts 1 looks to mean added.  The table has ProfileID and DiscoveredObjectID that can be joined on.  Setup a case statement on the status at that point.  I wish I had some more time to put the SQL together, but I hope my suspicious are correct and this helps get it worked out.
0 Kudos
Highlighted
Level 9
I just want to add myself to the list of those who want something like this.  I would like to know what nodes are added to discovery for the last <period of time>.  I think this is an import review point.  Is there nothing that provides that kind of information?
0 Kudos
