I'm pretty darn good with NPM and SAM. I've even gotten really (really) creative over the years is running 64-bit PowerShell scripts by wrapping them in a 32-bit vbScript. Needless to say, I'm pretty well versed. However, I've realized that I've hit a conundrum in configuring either the SAM Template or the Advanced Alerting Engine.
Here's what I've got: I've got two servers - call them EAST01 and WEST01. They are in opposite data centers and they run the same software. The software is made up of a set of services. Some of those services (4) are in an Automatic state and I monitor them all the time. The other services (3) are in a Manual state and should ONLY be running on one or the other server at any time. I've written a fairly simple PowerShell SAM Script to watch that this is running on one or the other. I'm including the script at the bottom.
This isn't a hard set of things to monitor, but I'd like to alert on when the returned value is "0" (service isn't running on either endpoint) and when there is a change (Server1 takes over for Server2 or vice-versa. To compount things, I've built a pretty decent custom view in Orion to show this stuff and I want to be able to "see" that these things are in place.
Yeah - it's more than my simple "here's a script to do..." type of posting, but I'm asking for some assistance.
Script Summary Follows:
$Server1Service = Get-Service -ComputerName $Server1IP -DisplayName $ServiceName
$Server2Service = Get-Service -ComputerName $Server2IP -DisplayName $ServiceName
$Server1OK = $Server1Service.Status -eq "Running"
$Server2OK = $Server2Service.Status -eq "Running"
$Server1Stat = $Server2Stat = 0
if ( $Server1OK )
$Server1Stat = 1
if ( $Server2OK )
$Server2Stat = 1
if ( $Server1OK -or $Server2OK )
Write-Host ( "Message.Summary: " + $ServiceName + " on " + $Server1Name + "/" + $Server2Name + " Pair is Online" )
Write-Host ( "Statistic.Summary: 1" )
Write-Host ( "Message.Node1: " + $ServiceName + " is " + $Server1Service.Status + " on " + $Server1Name )
Write-Host ( "Statistic.Node1: " + $Server1Stat )
Write-Host ( "Message.Node2: " + $ServiceName + " is " + $Server2Service.Status + " on " + $Server2Name )
Write-Host ( "Statistic.Node2: " + $Server2Stat )
$ExitCode = 0
else
Write-Host ( "Message.Summary: " + $ServiceName + " on " + $Server1Name + "/" + $Server2Name + " Pair is Down" )
Write-Host ( "Message.Statistic: 0" )
$ExitCode = 1
Exit ($ExitCode)
