cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
FTP Voyager does not work with Serv-U using FTP/FTPS protocols over TLS
We have had some complaints about connecting to our Serv-U server with FTP Voyager, because of these complaints I have decided to test it myself.
FTP Voyager version: 16.2.0.328
Serv-U version: 15.1.6.25
I don't have many SSL/TLS options for the FTP/FTPS protocols in FTP Voyager but it fails when it tries to read the SSL certificate. We use this solution:
Deploy Serv-U MFT in a cluster - SolarWinds Worldwide, LLC. Help and Support
This is the error:
FileZilla and FTP Voyager with the exact same settings, from the exact same computer, with the same user and at the same time. FileZilla works, FTP Voyager does not.
The log the Serv-U server shows when FTP Voyager wants to connect.
I have asked the Solarwinds support for help because we make use of their Serv-U solution but they do not support their FTP Voyager application, so they cannot help me.
Do you guys have any problems with FTP Voyager in combination with these solutions FTP explict FTP over TLS or FTP implicit FTP over TLS?
If yes, do you have any solution?
Tags (2)
0 Kudos
Level 7
The solution above used the following method:
This ment that I had a Loadbalancer between the client and the Serv-U server, the test below I have removed the Loadbalancer out of test.
FTP Voyager -> Loadbalancer -> Serv-U Gateway -> Serv-U MFT
This is what happens:
So this is an example using FTP Voyager with Serv-U's Gateway/MFT solution using their standard FTPS settings.
FTP Voyager -> Serv-U Gateway -> Serv-U MFT
Gateway (for Serv-U FTP and MFT Server) | Serv-U
Does anyone have any idea how we can get FTP Voyager to open a TLS session using FTP/FTPS?
0 Kudos
Did you get anywhere with this paulus; I'm experiencing the same issues?
Jamie
0 Kudos
