cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Settings getting ignored while using Mini Remote Control in a RDP session
Hello everyone,
I’m experiencing a strange issue I seem to be unable to fix and I was wondering if somebody might know why that is and how to fix it.
I work in a IT-Department and we are currently working from HomeOffice. We use our Laptops (VPN) to rdp onto a computer in the company and from there we use Mini Remote Control to connect to other computers at the company.
Technically this all works fine, but I noticed that it keeps ignoring the disabled desktop effects i.e.. hiding the wallpaper for better performance. Which makes everything very slow once you are connected. I tried different settings in this menu and my rdp session. I reset everything no change. When I am at the company everything works as it should, but once i am connected via rdp for some reason all these settings are getting ignored.
I would really appreciate it if someone could help me with this issue or has an idea why this is happening.
Thanks and Regards
Chris
0 Kudos
