cancel
Showing results for
Search instead for
Did you mean:
Create Post
FEATURE REQUEST - Inverted monitor.
Hi.
We're using screens that are mounted upside down that we need to control through Mini Remote.
So the Windows desktop is inverted, using "Landscape (flipped)".
The Mini Remote can't handle this today, either getting black or inverted screen depending on which version of Mini Remote we use.
Would be nice to be able to control these monitors even though they are inverted.
Have the option to invert the screen back when looking at it through Mini Remote.
Reported in Case # - 00477424.
Regards, Thomas Brännström
0 Kudos
