cancel
Showing results for
Search instead for
Did you mean:
SQL Server SQL Agent Alert - Monitor SQL Agent
Description
This alert uses the external stored procedure named xp_servicecontrol which is not supported. See this custom alert for an alternative: Monitor SQL Server Agent - No XP Proc
This alert will run against the monitored instance and determine if the SQL Agent is Started or Stopped.  If Stopped, this alert will fire and send the appropriate emails. The alert can be created in Ignite by clicking on Alerts > Manage Alerts and creating a custom alert of type Custom SQL Alert - Single Boolean Return.
SQL Statement
CREATE TABLE #status (status VARCHAR(50))
INSERT #status EXEC master..xp_servicecontrol 'querystate','SQLServerAGENT'
SELECT CASE status WHEN 'Started' THEN 'TRUE' ELSE 'FALSE' END FROM #status
DROP TABLE #status
Alert Definition
Labels (1)
Version history
Revision #:
1 of 1
Last update:
‎01-07-2015 04:28 AM
Updated by:
