DESCRIPTION
This custom report will list the Top N SQL statements in your repository for a list of databases provided. The database names should match the display name on the DPA (formerly Ignite) home page. To use this report, run it from SQL*Plus while connected to the Ignite repository database.
SQL*PLUS SCRIPT
prompt Enter starting time (mm/dd/yy hh24:mi)
accept StartDate
prompt Enter ending time (mm/dd/yy hh24:mi)
accept EndDate
select name from cond order by name
prompt List of databases to combine ('DB1', 'DB2', 'DB3', etc)
accept DBList
prompt How many SQLs should be shown
accept HowMany
DECLARE
nCount INTEGER := 0;
BEGIN
SELECT COUNT(1) INTO nCount FROM user_tables WHERE table_name='TOPSQLALLDB';
IF nCount > 0 THEN
EXECUTE IMMEDIATE 'DROP TABLE TopSQLAllDB';
END IF;
END;
CREATE GLOBAL TEMPORARY TABLE TopSQLAllDB(
dbname VARCHAR2(50),
sql_hash_or_name VARCHAR2(100),
timesecs NUMBER)
DECLARE
sSQL VARCHAR2(32767);
BEGIN
FOR r IN (SELECT id FROM cond WHERE name in (&DBList)) LOOP
sSQL := 'INSERT INTO TopSQLAllDB select * from ( ' ||
' select d.name, nvl(n.name, ss.sqlhash) sql_hash_or_name, sum(ss.timesecs) timesecs ' ||
' from con_sql_sum_'||r.id||' ss, con_sql_name n, cond d ' ||
' where ss.datehour between TO_DATE(:1,''mm/dd/yy hh24:mi'') and TO_DATE(:2,''mm/dd/yy hh24:mi'') ' ||
' and ss.sqlhash = n.hash ' ||
' and d.id = :3 ' ||
' group by d.name, nvl(n.name, ss.sqlhash) ' ||
' order by 3 desc) ' ||
'where rownum <= :4 ';
EXECUTE IMMEDIATE sSQL USING '&StartDate', '&EndDate', r.id, &HowMany;
END LOOP;
END;
set pagesize 999
set lines 130
column dbname format a40
column sql_hash_or_name format a30
select * from (
select dbname, sql_hash_or_name, timesecs
from TopSQLAllDB
order by timesecs desc)
where rownum <= &HowMany
