cancel
Showing results for
Search instead for
Did you mean:
Create Post
Custom Metric - Index Fragmentation
DESCRIPTION
This custom metric will track the fragmentation of an index
METRIC DEFINITION
To create the custom metric, click on Options > Custom Resource Metrics and configure the metric similar to this:
Database Versions: <no limitations>
Display Name: Index Fragmentation
Description: <add your own description>
Category: <add to whatevfer category you like or create a new one>
Units: %
Metric Type: Single Value
Frequency: 900
Timeout: 50
SQL Statement:
Use [Database]
SELECT round(avg_fragmentation_in_percent, 0) FROM sys.dm_db_index_physical_stats(DB_ID(N'Database'), Object_ID(N'Database.Table'), INDEXPROPERTY(OBJECT_ID('Database.Table'), 'Index_Name', 'IndexID'), NULL , NULL)
Labels (1)
Version history
Revision #:
1 of 1
Last update:
‎11-04-2019 04:19 PM
Updated by:
