cancel
Showing results for
Search instead for
Did you mean:
Create Post
Locked out of DPA - HELP!
Jump to solution
My friend, the database administrator was recently let go from our organization.  There was no malice, no matter what you all are thinking!
I am listed as an administrator of DPA.  There are a couple of things that were done to DPA right before his departure, and I am not certain what exactly is happening.
DPA is running current SW version 2020.2.731, on Server 2016.  Most recently, the DBA did a SQL "patch".  That is about all the information that I have to offer.
I have a password but no user name with this information:
To help protect against users that might enter malicious SQL, a special password needs to be set up. To configure the password:
1. Open the directory DPA_INSTALL_DIR/iwc/tomcat/ignite_config/iwc/security
2. Edit the authorization file and enter the password.
All future changes to Custom Metrics and Custom Alerts will require users to enter the password.
Any ideas on how I can get into DPA?  I am ready to do a fresh installation and dump the current metrics!
@KMSigma
@sqlrockstar
Labels (1)
Tags (1)
1 Solution
I got in just a few minutes ago .. LDAP was not working, which really messed everything up.  I was able to modify the config file ... called system.properties - I changed the url and service account -
Had to become zen with the issue, then I was able to find supporting documentation: - https://support.solarwinds.com/SuccessCenter/s/article/Resolving-AD-LDAP-connection-errors-in-DPA?la...
Thanks @yumdarling & @chrisorourke
Community Manager
Community Manager
Did you get this resolved? Anything I can do from my end? (other than the obvious - running around like a headless chicken)
Level 11
Can you login to the SQL server itself to determine what usernames are active on that SQL instance? Short of that you can have a domain admin add a new full rights SQL user and then reconfigure DPA to use those credentials instead. I'd highly recommend you ensure your org is properly storing user/pass info somewhere everyone is aware of and controlled via access rights not a spreadsheet with a password on it.
1password teams is a cheap dependable option as is a dedicated password access server from thycotic for a small team.
0 Kudos
