How to send DPA Alert to external logging/ticketing system?
what are ways that DPA's can interface with other software/systems?   eg: Take info from an alert and send it to an 'auto-ticketing system'. or out put alert info to text or log file
  • Currently, DPA can send alerts via SMTP and SNMP traps. As long as the ticketing system could consume one of those methods, you should be OK.
    We ship DPA with a MIB file that you can look at for the SNMP traps (it's in <install_dir>/iwc and called CONFIO-MIB.mib
  • Hi,
    thanks for the rapid response!    this is new territory for me but it looks like other posts will be able to answer any questions i have.
  • We use the SNMP alerting option, so when we have a CRITICAL issue pop-up our notification get's sent to SLACK using their e-mail hook.  Once the e-mail hook is installed/configured in our channel of choice a unique email address is generated.  That account is placed into group inside of DPA that I use for alerting.  Those alerts then get sent to SLACK and our team responds accordingly.  For us it's the most efficient way to handle issues.
  • we have an official system/process for handling critical alerts.   instead of email or slack, we have an auto-ticketing system that can ping the on-call person.
    now I just need to find out how to send as much info when an alert happens.  eg: for DEADLOCKs, send server, DB, SQL, SPID's, etc.   this would speed up investigation/resolution.
