cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 8
How to get Interface status and LED icon on this SQL script
Jump to solution
I need some help whit this SQL script i have used in the Report. Need to get the Status of the interface if its up or down and whit LED icon. Can anyone help whit this?
select
Interfaces.nodeID AS NodeID,
Nodes.Caption AS NodeName
interfaces.caption AS InterfaceName,
interfaces.interfaceIndex,
NodeIPAddresses.IPAddress,
NodeIPAddresses.InterfaceIndex
from
Interfaces
Right join nodes on (nodes.nodeID = interfaces.NodeID)
Left join NodeIPAddresses on (NodeIPAddresses.nodeid = interfaces.nodeid AND NodeIPAddresses.InterfaceIndex = interfaces.interfaceindex)
WHERE (NodeIPAddresses.IPAddress IS NOT NULL AND Nodes.Caption like 'SB1-%')
ORDER BY Nodes.Caption, interfaces.caption
Tags (2)
0 Kudos
1 Solution
you can try something like
select interfaces.nodeid as [nodeid], nodes.caption as [node name], interfaces.caption as [interface name],interfaces.interfaceindex as [interface index],interfaces.status as [status id],statusinfo.statusname as [status],
concat('<img src="/Orion/images/StatusIcons/small-',interfaces.statusled,'"/>')
from interfaces
join nodes on nodes.nodeid = interfaces.nodeid
join statusinfo on statusinfo.statusid = interfaces.status
0 Kudos
