cancel
Showing results for
Search instead for
Did you mean:
Create Post
Level 7
Custom Alert - best practice for a long running query?
I have a custom alert that runs daily, and the query takes about a minute. I noticed it was the victim of a deadlock recently, and I want to ensure that it will always be the victim. The target is SQL Server 2012.
Does DPA use a low priority session? Is there something I should do to ensure that my custom alert's query won't win in a future deadlock event?
There's little I can do to improve this particular query, and it's reading from a large table that can't be altered. I can't create new indexes on it; that would invalidate product support.
Labels (1)
0 Kudos
1 Reply
Level 17
@SeanM
Not sure DPA sets the deadlock priority to be low. You could try putting this code at the top of the custom alert script and see if it works:
SET DEADLOCK_PRIORITY LOW;
<custom alert script here>
HTH
0 Kudos
