cancel
Showing results for
Search instead for
Did you mean:
Create Post
Is it possible to build a graph with thin Cisco AP's?
Hi Thwack folks!
Is it possible to build a graph/view with quantity of thin AP's per WLC? I know that there is a list of them but you need to enter to each WLC to see them and it would be helpful to get than number visible for example in a NOC View.
Workarround accepted indeed.
Thank you!
0 Kudos
