As I understand it, unless I set an alert to repeat the trigger action using the Escalation option, then an alert will only fire once until a defined reset condition is met. Correct? Assuming that is correct, it seems that I can force a trigger action to re-fire if I disable the alert and then re-enable it. Is that also true, and if so, is it because disabling the alert clears the triggers from the database?
Thank you.t, trigger, refire
