Hello,
i have created my own template for creating users.
In this template I have included a script:
"ScriptOptions": {
"IsHidden": false,
"IsHiddenFromRequester": false,
"IsScriptEnabledByDefault": true,
"Path": "xxx",
"CommandLineParameters": "xxx",
"DisplayName": "xxx"
The script itself works fine.
But I have to select the execution of the script manually each time:
Shouldn't the "IsScriptEnabledByDefault" switch ensure that the script is executed automatically?
Another problem:
The default template for creating new users shows me the "Scripts" tab, where I can select the scripts I have defined in the "ARM Configuration" tool.
With my own template I can't use the predefined scripts, but have to define the scripts directly in the template.
Can I also use the predefined scripts in my own template?
Best regards
Jonas
Solved! Go to Solution.
Hello,
according to documentation i think the switch has to be "IsScriptEnabledDefault" instead of "IsScriptEnabledByDefault".
If you add the section "ScriptOptions" to user defined template, then you define one specific script the will be executed or not.
When you remove the section "ScriptOptions" from the template, then you can select the scripts that were defined in ARM configuration.
You can find more information on this topic here:
https://documentation.solarwinds.com/en/Success_Center/ARM/Content/run-an-external-program.htm
Kind regards
Christian
Hello,
Kind regards
Christian
Hello Christian,
you're absolutely right, my bad!
Thanks a lot
Best regards
Jonas
SolarWinds solutions are rooted in our deep connection to our user base in the THWACK® online community. More than 150,000 members are here to solve problems, share technology and best practices, and directly contribute to our product development process.
