Access Right Management File System
Hi there,
I'm evaluating a solution for file access right on Windows systems .
SolarWinds ARM seems good, but i don't have fully cleary if cover some needs.
I have following questions:
- Do ARM work only on unstructured data?
- Can ARM manage permissions on files and folders taken on a local file system on a server?
- Does it manage local accounts (user/groups)?
- Does it manage of local users of Windows systems in SoD mode (who creates the users must not be able to use them) ?
- Can an administrator obtain permissions without authorization?
Many Thanks
  • Hi,
    regarding your questions:
    It doesn't matter if the data is structured or not, ARM will work with it. See it as a software changing the way you adminstrate your ressources.
    ARM does not manage files permissions (you shouldn't do that anyway). One of the ideas is that ARM automatically creates permission groups, sets permissions for them on the folders and traverse permission on the parents so you can navigate there.
    The strongest point of ARM is showing you what are the "real" permissions by going way beyond the flat ACL.
    No, local accounts (on the server) are not managed. What's your use case for this?
    As previously stated it does not manage local accounts. And this is a matter of trusting your employees (if you don't, you're already destined to fail in my opinion) and which permissions you give them. Of course theoretically this could be done, but this could be done by any admin in theory. Users configured as Data Owners with the ability of creating users of course could use them in theory. But that's why everything is logged and can be reviewed.
    What's you definition of administrator here? If you mean an ARM administrator, then: yes, of course. Administrators are not limited. Data Owners can be limited, but must be apporved by administrators (RichClient) or whatever you configure in the WebUI for workflows.
    Cheers
    Björn
