cancel
Showing results for
Search instead for
Did you mean:
vasileios
Level 7
ARM web configuration issue
Hi
i have already instaled solarwinds ARM but i made a mistake to ARM server wich provides the data to present during the web configuration first setup and now i cant change it.
i inserted a domain ip adress where i should have localhost.
Is there any way to change this setting.
0 Kudos
1 Reply
vasileios
Level 7
Re: ARM web configuration issue
i found the solution
you can change the Web Configuration ARM Server by editing the grantMA.config.xml in c:\ProgramData\protected-networks.com\8man\cfg  folder and replace the wrong server with the correct one.
Regards everyone
