Can I run the same scenarios for both poc and live websites in wpm?
Our product has a poc and a prod version with the exact same structure, only the URL is different. I have successfully written and saved my test scenarios on poca.com and run them regularly. I want to use these ready-made on proda.com, which is live and has the same internal structure as poca. If I edit go to poca.com, which is the first step of the same scenario, in the recorder and convert it to proda.com, can I run my tests successfully in the same way? Or do the scripts need to be re-recorded separately?
