Virtualization Summary view is missing on the Node Details view for a VM
I have HCO AES.
I am noticing that the Virtualization Summary view (left navigation) is not showing on the Node Details for a VM that is also managed as a node in NPM. The view is set to be shown if the "Virtualization Manager integration is enabled and the user has permission to see the collected data" - which I believe is true. If I change the Virtualization Summary to "Always" be shown, then of course it does show. How do I verify that virtualization manager integration is enabled, or does that even mean anything with HCO? I'm confused. Appreciate the help.
