Path Folder count monitoring
Hi All,
I am looking for a PowerShell script that can check path and count how many folder available in that path
example i have a path : \\XXXXSSQLP01\Team\work
if we have 2 or more folders available in that path alert will triggred
can any one help in this
thanks
Sumit Goel
  • This is more than an alert.  You need to first build a monitor in SAM to check for the folder count.  There's an out of the box one that does it using PowerShell, but this is basically what it does.
    $Folders = Get-ChildItem -path \\ServerName\SharedFolder\ChildPath -Recurse -Folder
    if ( $Folders.Count -ge 2 ) {
        Write-Host "Message: We found $( $Folders.Count ) Folders - that's bad"
        Write-Host "Statistic: $( $Folders.Count )"
    else {
        Write-Host "Message: We found $( $Folders.Count ) Folders - that's good"
    Then you just need to alter the definition of the component so that if the statistic is 2 or more, it returns a critical status.
    Then the alert is easy: Alert when a component name is "Whatever you called this component" and the status is "Critical" fire an alert.
  • could you please below script for file monitor? and suggest if any changes required
    get-childitem 'PATH' |
        select @{n='Date';e={$_.LastWriteTime.ToShortDateString()}} |
        Group-Object Date |
        Format-Table Name, Count
    IF ($Count -gt 2)
        $Message = 'there are wrong/duplicate files generated'
                  Write-Host 'Statistic.Status: '2
                  Write-Host 'Message.Status: '$Message
    ELSE
        $Message = 'there are no wrong/duplicate files generated'
                  Write-Host 'Statistic.Status: '1
    ######## End Script #########
  • sorry but i am looking for file count monitoring for latest date
    i have prepared some thing but not able to print latest count with date
    get-childitem '\\NJIOILMSSQLU01\ilmsdata\VendorExport\NachaExport' |
    Group-Object Date |
    IF ($Count -gt 2)
    ELSE
  • Are you only looking for files after "today" or in the last 24 hours or something else?  Please be as specific as possible so we can help craft this.
  • for current date file count
    Name Count
    5/31/2022 2
  • So at 12:01 AM, this might return 0 files - just so you are aware.
    $Today = Get-Date | Select-Object -Property Date | Get-Date
    $Path = "\\Path\To\Check"
    $Files = Get-ChildItem -Path $Path -Recurse -File -Force -ErrorAction SilentlyContinue | Where-Object { $_.LastWriteTime -ge $Today }
    Write-Host "Message: Found $( $Files.Count ) files in $( $Path ) created on $( $Today.ToString("MM/dd/yyyy") )"
    Write-Host "Statistic: $( $Files.Count )"
    Message: Found 1836 files in \\Path\To\Check created on 06/01/2022
    Statistic: 1836
  • Here is a way to show both ways (since midnight today and within the last 24 hours)
    # Things since midnight today
    $FilesToday = Get-ChildItem -Path $Path -Recurse -File -Force -ErrorAction SilentlyContinue | Where-Object { $_.LastWriteTime -ge $Today }
    # Things since this time yesterday
    $Last24Hours = ( Get-Date ).AddDays(-1)
    $FilesLast24Hours = Get-ChildItem -Path $Path -Recurse -File -Force -ErrorAction SilentlyContinue | Where-Object { $_.LastWriteTime -ge $Last24Hours }
    # Results for 'today'
    Write-Host "Message.Today: Found $( $FilesToday.Count ) files in $( $Path ) created on $( $Today.ToString("MM/dd/yyyy") )"
    Write-Host "Statistic.Today: $( $FilesToday.Count )"
    # Results for 'Last 24 hours'
    Write-Host "Message.Last24Hours: Found $( $FilesLast24Hours.Count ) files in $( $Path ) created on or after $( $Last24Hours.ToShortDateString() ) $( $Last24Hours.ToShortTimeString() )"
    Write-Host "Statistic.Last24Hours: $( $FilesLast24Hours.Count )"
  • Thanks
    Ill test and get back to you Slight smile
  • its showing wrong
    Found 0 files in PATH created on 06/01/2022
    2 file available there
