When Installing SQL Sentry - I want to install on its own SQL Server... and why ... should I?
I have an application running in my environment on all Server 2016 and SQL 2016.   The application may get upgraded in the near future.   I am all jazzed about getting SQL Sentry installed for my DBA.   I don't want to install it and attache it to a server running SQL 2016 then go thru the pain of the upgrade.   I know that it will cost to run another instance of SQL, but feel that it is the right thing to do.   I want to load both the console and database on the same server as we will use this for no more than 10 SQL servers.
What are the pros or cons?   Can I even do this?  What would you all do?   I am not a DBA, I just know that I loved the SQL Sentry demo and that this is the tool that we need in our environment.
I need advice and a push in the right direction!  Love you guys!   Throw this chick a bone please!!!
  • Hey there !
    In general, yes, you can host the SQL Sentry repository database, Monitoring Service, Portal, and Client all on the same host if you would like!  For a smaller deployment of 10 targets, this should be fine as long as the host has sufficient resources.  Take a look at https://docs.sentryone.com/help/recommendations#s1dbserver and scroll down to the section for 10 targets.  Since these requirements are for the database server alone, you may need to add a little bit more memory for the extra services/apps running on there.  Maybe try with 16-24 GBs of memory and see how the product performs?
    The pros that jump to mind of cohabitating everything, you've already identified: minimizing licensing cost for the host and SQL Server.  It also puts everything in one place for ease of use.  The cons would be a lot of resource competition between the SQL Sentry + SQL Server processes, and also having a single point of failure.
    Now for the $64,000 question...what would I do?  I'd start with everything on the same host and see how it goes!  If the performance is lacking a bit, it's easy enough to install the Monitoring Service, Portal, or Client features on a different machine later on.
    Let me know if you have any other questions!  We'd love to help!
  •   took your advice, installed it on the same server!   Got great details already!!!   I do need to add more memory... I am already blown away by the individual server dashboards, can't wait to get my DBA into the environment ... even though I just manage the infrastructure, I have learned how to read DPA results so that I could push the "old" DBA to fix issues.   We now have a new DBA that cares, I just needed to provide him with the right tools and documentation!  Thanks for your advice... I stand alone most of the time ... I use a lot of common sense and over 25 years in the trenches interfacing with people much smarter than myself!   This is quite an amazing tool!  Solarwinds is quite amazing!   No one ever makes me feel like I am incompetent!   Thanks again for taking time to provide your insight!  Means the world to me!
    Jennifer
