Sentry One on Azure Data Studio
I followed these instructions to install:
https://sqlperformance.com/2019/08/sentryone/plan-explorer-extension-azure-data-studio
I made sure my version is greater than 1.9.0 (mine is 1.43.0)
I installed .net 2.1 for MacOS
When I try to toggle on the sentry plan explorer I get this error :  'command 'planViewerAds.showInPlanViewer' not found". Does anyone know what this error means?
  • bump - Azure Data Studio (v1.43) running on MacOS Ventura, I've tried brew intalls of both dotnet-v6 (arm64) and latest dotnet-v7 (arm64) runtimes, exact same notification appears. It is a great plug-in when it works, nevertheless i fear it's no longer supported (since late 2020).
