Hi!
We are debating whether we should go physical or virtualized with our SolarWinds Orion environment. We used to have a physical failover cluster on a MSSQL Standard Edition license. We are now running on a virtualized environment on a single node. We are discussing which direction to go; virtualized with AlwaysOn, or go back to our physical failover-cluster. And furthermore, we are discussing whether we should upgrade to a MSSQL Enterprise Edition license.
Our environment is currently running with 55000 elements and 285000 SAM component. Zero downtime is very important.
We are having a hard time finding any metrics that directly indicate a need to go virtual, and the same for upgrading to Enterprise. We are aware that the limitation on memory and CPU cores on a standard edition might be a bottleneck, but can't seem to find any direct proof that upgrading would justify the cost of upgrading to Enterprise.
Has anyone been in the same situation? And if so, would you recommend virtual or physical, and what would your take on Standard vs Enterprise be?
