I created a map with Orion Maps and have several sub maps linked with it. The only problem I have, is when a node on the submap goes down it will not show on the map until I either manually reload the entire page or reload the widget. Is there a setting somewhere that will make the map widget refresh every 45 secs like my other widgets? My other widgets are working fine, the auto refresh appears to solely on the Map Widget.
