Need SWQL Assistance on VPN Connection Counts
I able to use the following SWQL Query to get a total session count for all my VPN appliances.
SELECT DISTINCT
count ([data].[RemoteAccessSessions].[UserName]) AS [Total Sessions]
FROM orion.asa.node AS data
where [data].[RemoteAccessSessions].[EncryptionAlgorithm] = 1
and ([data].[RemoteAccessSessions].[NodeId] = XXX or [data].[RemoteAccessSessions].[NodeId] = XXX or [data].[RemoteAccessSessions].[NodeId] = XXX or [data].[RemoteAccessSessions].[NodeId] = XXX) and [data].[RemoteAccessSessions].[DisconnectedTime] is null
However, I would like to also display the individual count for each node in the same SWQL Query as well.
Total Session = ### , Node 1 Sessions = ###, Node 2 Sessions = ###
  • How are you currently displaying this information, are you using a modern dashboard kpi widget?
  • FYI, I was able to figure this out on my own with a little help from ChatGPT,  here is what the final results look like
    SELECT
        COUNT(CASE
                  WHEN [data].[RemoteAccessSessions].[EncryptionAlgorithm] = 1
                       AND ([data].[RemoteAccessSessions].[NodeId] = XX11 OR
                            [data].[RemoteAccessSessions].[NodeId] = XX21 OR
                            [data].[RemoteAccessSessions].[NodeId] = XX12 OR
                            [data].[RemoteAccessSessions].[NodeId] = XX22)
                       AND [data].[RemoteAccessSessions].[DisconnectedTime] IS NULL
                  THEN [data].[RemoteAccessSessions].[UserName]
              END) AS [Total Sessions],
        COUNT(CASE
                            [data].[RemoteAccessSessions].[NodeId] = XX12)
              END) AS [Data Center1 Sessions],
        COUNT(CASE
                       AND ([data].[RemoteAccessSessions].[NodeId] = XX21 OR
              END) AS [Data Center2 Sessions]
    FROM
  • I am getting no results from the query.  I have only one Cisco 5525x ASA.  Can you help?
  • I have single ASA using this code with an error.
    SELECT
    COUNT(CASE
    AND ([data].[RemoteAccessSessions].[NodeId] = 204
    FROM
  • I am looking for a query to show me who has a remote VPN connection using Cisco Anyconnect, how long they have been connected, and how many MB they have used.
    I am looking at the following fields:
    Table:  ASA_RemoteAccessSessions
    Columns:  UserName,     SessionStatus=1,     ConnectedTime, DisconnectedTime,     InTotalBytes;    OutTotalBytes
  • I believe most of that info is already available under Remote Access VPN as part of the ASA Node Details
  • GPT's method worked
    Usually you can get away with ~:
    Select x.parent.name, Count(ID) as [Count],
    From X
    Group by x.parent.name
