Custom SQL / SWQL for alerts history - SLA reporting
I am looking for a SQL or SWQL query that helps me to extract a report of alerts history / active alerts which contains the following information:
Caption (Hostname), IP address, Object (Interface or node or any resource), Alert trigger time, Alert close time, Alert active time / Total time duration (in minutes/hours/days), Acknowledged or not, Acknowledged by, Alert name, Alert severity, Object Type (Node, Volume, Application etc).
Can anyone please help me in the above requirement?
  • It looks like I have all the things you are asking for, but they arent in a single query.  This should give you enough to piece it all together how you like.
    Active alerts
    SELECT
     o.AlertConfigurations.Name AS [ALERT NAME]
     ,'/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:' + ToString(o.AlertObjectID) AS [_LinkFor_ALERT NAME]
    ,CASE
    WHEN o.AlertConfigurations.Severity = 2 THEN '/Orion/images/ActiveAlerts/Critical.png'
    WHEN o.AlertConfigurations.Severity = 3 THEN '/Orion/images/ActiveAlerts/Serious.png'
    WHEN o.AlertConfigurations.Severity = 1 THEN '/Orion/images/ActiveAlerts/Warning.png'
    WHEN o.AlertConfigurations.Severity = 0 THEN '/Orion/images/ActiveAlerts/InformationalAlert.png'
    WHEN o.AlertConfigurations.Severity = 4 THEN '/Orion/images/ActiveAlerts/Notice.png'
    END AS [_iconfor_ALERT NAME]
     ,case when o.entitycaption = o.RelatedNodeCaption then o.EntityCaption
     else concat(o.RelatedNodeCaption, ' - ', o.entitycaption) end AS [ALERT OBJECT]
     ,o.EntityDetailsURL AS [_LinkFor_ALERT OBJECT]
     ,ToLocal(o.AlertActive.TriggeredDateTime) AS [ALERT TRIGGER TIME]
    -- ,o.AlertActive.TriggeredMessage AS [ALERT MESSAGE]
    --,'/Orion/images/StatusIcons/Small-' + n.StatusIcon AS [_IconFor_ALERT OBJECT]
    ,'/Orion/images/StatusIcons/Small-' + p.StatusIcon AS [_IconFor_RELATED NODE]
    ,CASE
    when minutediff(o.AlertActive.TriggeredDateTime,GETUTCDATE())>1440 then (tostring(round(minutediff(o.AlertActive.TriggeredDateTime,GETUTCDATE())/1440.0,1)) + ' Days')
    when minutediff(o.AlertActive.TriggeredDateTime,GETUTCDATE())>60 then (tostring(round(minutediff(o.AlertActive.TriggeredDateTime,GETUTCDATE())/60.0,1)) + ' Hours')
    else (tostring(minutediff(o.AlertActive.TriggeredDateTime,GETUTCDATE())) + ' Minutes')
    end as [Time Active]
    , o.AlertIncident.IncidentNumber as Incident
    , o.AlertIncident.IncidentUrl as [_linkfor_Incident]
    From Orion.AlertActive aa
    join Orion.AlertObjects o on aa.alertobjectid=o.alertobjectid
    LEFT join Orion.Nodes p on p.nodeid=relatednodeid
    left join orion.alerthistory ah on ah.AlertActiveID=aa.AlertActiveID and ah.EventType in (2,3)
    -- WHERE o.AlertConfigurations.Name Like '%Restart%'
    ORDER by o.AlertActive.TriggeredDateTime DESC
    Alert SLA
    --report on alerts triggered
    select ac.Name
    ,ah.Message
    ,'/Orion/NetPerfMon/ActiveAlertDetails.aspx?NetObject=AAT:'+ToString(AlertObjectID) as [_linkfor_Name]
    ,EntityCaption as [Trigger Object]
    ,EntityDetailsUrl as [_linkfor_Trigger Object]
    ,case
    WHEN RelatedNodeCaption=EntityCaption THEN 'Self'
    When RelatedNodeCaption!=EntityCaption THEN RelatedNodeCaption
    End as [Parent Node]
    ,RelatedNodeDetailsUrl as [_linkfor_Parent Node]
    ,'/Orion/images/StatusIcons/Small-' + p.StatusIcon AS [_IconFor_Parent Node]
    ,tostring(tolocal(ah.TimeStamp)) as [Trigger Time]
    ,case when ack.timestamp is null then 'N/A'
    else tostring(minutediff(ah.TimeStamp,ack.timestamp))
    end as [Minutes Until Acknowledged]
    ,ack.Message as [Note]
    ,case when reset.timestamp is null then 'N/A'
    else tostring(minutediff(ah.TimeStamp,reset.timestamp))
    end as [Minutes Until Reset]
    FROM Orion.AlertHistory ah
    left join Orion.AlertObjects ao on ao.alertobjectid=ah.alertobjectid
    left join Orion.AlertConfigurations ac on ac.alertid=ao.alertid
    left join Orion.Actions a on a.actionid=ah.actionid
    left join Orion.Nodes p on p.nodeid=RelatedNodeID
    left join (select timestamp, AlertActiveID, AlertObjectID,message from orion.alerthistory ah where eventtype=2) ack on ack.alertactiveid=ah.AlertActiveID and ack.alertobjectid=ah.AlertObjectID
    left join (select timestamp, AlertActiveID, AlertObjectID from orion.alerthistory ah where eventtype=1) reset on reset.alertactiveid=ah.AlertActiveID and reset.alertobjectid=ah.AlertObjectID
    WHERE
    daydiff(ah.timestamp,GETUTCDATE())<30
    and ah.eventtype=0
    --and (ac.Name like '%${SEARCH_STRING}%' or EntityCaption like '%${SEARCH_STRING}%' or RelatedNodeCaption like '%${SEARCH_STRING}%')
    order by ah.timestamp desc
  • Thank you   for quick response. This solves the purpose. Just need one more thing to add in both the queries.
    Can you help me appending these columns?
    1. Acknowledged (Yes/No), Acknowledged By in Active Alerts query.
    2. For Alert SLA Query: Instead of daydiff(ah.timestamp,GETUTCDATE())<30 how can I use Between function for figuring out specific duration of alerts history please?
    Thank you....
  • You can't use the between function for calculating durations, it is just a shorthand for saying where timestamp > A and timestamp < B, its not a math function.
    My Alert SLA query has the calculations for comparing the time of the trigger event to the time of the close event to calculate the duration. Lines 19-21 cover that.
    And the Acknowledged is covered there in 15-17, right now its displaying N/A or a timestamp, but if you just want it to be t/f you change the case to be False where I have the N/A and change the the else to "True"
  • mesverrum on your script for the Active Alerts could it be possible to reduce this from all active alerts for all nodes to active alerts on nodes within a custom property variable to allow it to be added to dashboards based on those specific custom property nodes?
  • Yeah, lots of ways to make that happen.  For example you could modify the query to have something like where p.customproperties.yourproperty = 'yourvalue'
    If I'm using them in dashboards i hate having to edit every query one by one so I'd most likely just apply a dashboard limitation based on the property or a group membership.
