NCM Config change management approval on jobs
Is there no way to enable the config change approval system when running jobs?  When you enable the approval system, that works when you go to a particular node and submit.
But, if you have users that need to make changes to multiple devices, potentially hundreds, there's no approval system for this?  They either have permissions to run jobs or they don't?
Please advise!!!
Thanks.
