Backing up configs from Netgear GS752TPv2
I have some Netgear GS752TPv2 switches that I'd like to get set up in CatTools.
I've updated their firmware to one that supports SSH access, and can successfully log into the devices using TeraTerm, putty, etc. using SSH. The login prompt is login as:
However, I've been unable to get CatTools to connect to the devices successfully. I keep getting an error that it Did not receive command prompt after connecting via SSH. I have the device set to a connection method of SSH2, SSH Username of admin and setting the SSH password, and checking the box that initial login requires username and password. I've also set the Username field on the Prompts tab to login as: but that didn't make a difference.
Has anyone successfully been able to pull configs from these devices using CatTools?
