EOC, SQL, SWQL for reports
We have a report written in sql that use to reside on a MS Reporting server.
The frame work is as follows in SQL
;with BaseQuery as (
select distinct
n.Caption Node_Name,
n.Description,
p.Network_Zone,
TotalResourceUnit = 1,  (in SWQL  this line looks like  '1' AS [TotalResourceUnit],   (thank you dgsmith80​)
Active_Port_Count =
(select COUNT(i.status) from Interfaces i where i.NodeID = n.NodeID and (i.Status = 1 or i.Status = 2)
and
((i.InterfaceName like '%eth%') or (i.InterfaceName like '%gi%') or (i.InterfaceName like '%mgmt%') or (i.InterfaceName like '%xe%') or (i.InterfaceName like '%ge%') or (i.InterfaceName like '%unit%'))
and
(i.InterfaceName not like '%.0')),
From
inner join
where
select RU,
       SUM(Active_Port_Count) as 'Active Port Count',
       from BaseQuery
Group by RU
order by RU
A few things to note I had to strip this down for obvious reasons like keeping me out of trouble.
There are several queries similar in nature to Active Port Count. My logic get one get them all.
IN SQL I joined 2 tables
IN SWQL I have to join 3 tables since custom properties do not appear in the orion.nodes like the Nodes view, so in SWQL my joins look like this:
FROM Orion.Nodes n
INNER JOIN Orion.NodesCustomProperties p ON p.NodeID = n.NodeID
INNER JOIN Orion.NPM.Interfaces i ON i.NodeID = n.NodeID
Any help would be appreciative my first take at SWQL had to be a more complex one then what i saw in my research.
Thank you in advance
  • I'm a bit confused, am I reading correctly that active port count just returns the total of ports that are up or down and match the naming filters?  This query is really extremely complicated compared to what it should be.
  • it is stripped down for the sake of the forum.  There are other items included that i did not show.
  • Well for what you are showing I would write it like so
    select
    n.caption as Node_Name
    , n.Description
    , n.customproperties.Network_Zone
    , 1 as [TotalResourceUnit]
    count(i.status) as [Active_Port_Count]
    from orion.nodes n
    join orion.npm.interfaces i on i.nodeid=n.nodeid
    where
    or i.InterfaceName like '%gi%'
    or i.InterfaceName like '%mgmt%'
    or i.InterfaceName like '%xe%'
    or i.InterfaceName like '%ge%'
    or i.InterfaceName like '%unit%')
    and
    group by
    n.caption
    , n.Description
  • The statement provided mesverrum​ definitely worked. However I am not doing a good explaining what we are try to convert.
    So with a few mods this report is what we are trying to run out of the EOC, since now we have several orion primary with DB at various locations that feed the EOC.  We use to run this in SQL Reporting Server, but that option will not be available much longer.
    select distinct
    n.Description,
    n.Location,
    n.MachineType,
    n.Status,
    n.City,
    n.AssetTag,
    n.Device_Function,
    n.SerialNumber,
    n.Network_Zone,
    n.Number_of_Physical_Devices,
    TRU = 1,
    n.RU,
    Active_Port_Count =
    and
    and
    Inactive_Port_Count =
    (select COUNT(i.status) from Interfaces i where i.NodeID = n.NodeID and (i.Status <> 1 and i.Status <> 2)
    and
    and
    Total_port_Count =
    and
    and
    from[SolarWindsOrion].[dbo].[Nodes] n
    inner join [SolarWindsOrion].[dbo].[Interfaces] i on i.NodeID = n.NodeID
    where n.Security_Boundary = 'XXX'
    and RU <> 'EMCO')
    select RU,
           SUM(TRU) as 'TRU-tot',
           SUM(TRU) as 'NPD',
           SUM(Total_port_Count) as 'Total Port Counts'
    from BaseQuery
    Group by RU
    order by RU
