EOC 2.2 Compatible Modules???
I'm looking to figure out exactly which modules and versions are supported by the new EOC 2.2 release. I can't seem to find a list in their documentation like I've seen in other module releases. Even a list of which modules are NOT supported for sure would help. I would assume SEM isn't supported since it's not on the Orion platform, but just curious if there's others. Thanks!!!
