SWQL, EOC and Select commands
Since we have the EOC2.2, we  are trying to convert some custom reports that we did in MS Reporting server to SWQL. We learned a few things.
Custom properties do not appear in the nodes view when using the swql studio however that info does appear in Orion.NodesCustomProperties.
So there are two things I am stuck on. However this post will cover the first one.
select
    n.Caption,
    n.Description,
    n.Location,
    n.MachineType,
    n.Status,
    p.City,
    p.AssetTag,
    p.Device_Function,
    p.SerialNumber,
    p.Network_Zone,
    p.Number_of_Physical_Devices,
  TotalResourceUnit = 1,
   i.ObjectSubType,
   p.Resource_Unit_Name
From Orion.Nodes n
inner JOIN Orion.NodesCustomProperties p on p.NodeID = n.NodeID
inner JOIN Orion.NPM.Interfaces i on i.NodeID = n.NodeID
This query fails!
If I take:
out of the query it works.
I realize SWQL is a readonly language.  I also realize  that   TotalResourceUnit = 1, is creating for a lack of a better term a column.  I need that column or the rest of the query for the report wont work.
How can I make this TotalResourceUnit = 1 work?
Thank you in advance!
Parents
  • The query probably needs to look like this:
    SELECT
        n.Caption,
        n.Description,
        n.Location,
        n.MachineType,
        n.Status,
        p.City,
        p.AssetTag,
        p.Device_Function,
        p.SerialNumber,
        p.Network_Zone,
        '1' AS [TotalResourceUnit],
        i.ObjectSubType
    FROM Orion.Nodes n
    INNER JOIN Orion.NodesCustomProperties p ON p.NodeID = n.NodeID
    INNER JOIN Orion.NPM.Interfaces i ON i.NodeID = n.NodeID
Reply
    SELECT
        n.Caption,
        n.Description,
        n.Location,
        n.MachineType,
        n.Status,
        p.City,
        p.AssetTag,
        p.Device_Function,
        p.SerialNumber,
        p.Network_Zone,
        i.ObjectSubType
    FROM Orion.Nodes n
Children
