multiple count statements in SWQL and columns
In SWQL Studio, both queries work fine. However when I try to make these to queries one table it fails
I breviated column names in example below.
I tried a lot of varaiations that is why I just broke it down to its simplest form instead of showing all the things that did not work.
1.
SELECT DISTINCT
RUN,
Count(*) AS PD
FROM Orion.NodesCustomProperties
     where NOPD > '0'
Group by RUN
order by RUN
2.
SELECT DISTINCT
RUN,
Count(*) AS SBUPD
    WHERE NOPD > '0'
    AND SB like 'SBU%'
Group by RUN
order by RUN
Thank you
Parents
  • Thank you.
    That worked. We modifed it a bit as that is the building blocks for a much bigger query; that we are still working on.  A fe things to note
    1. WHERE NOPD > '0' we picked a better field to help with nulls then my originbal post (NodeID)
    2 We added a thrid colum, to prevent Nulls eliminating a RUN we used "left outer join instead" of join; of course mesverrum had no idea we were going further.
    3. once step 2 was done we made it so if a column had a null value it could change to zero changing
    ncp.RUN,
    Count(*) AS PD
    , sbu.SBUPD
    to
    ncp.RUN,
    Count(*) AS PD
    isnull (sbu.SBUPD,0)
    also we had third column, but you get the idea I hope.
    The last part we have to wourk out is RUN has the same names in multiple databases hence why building from EOC, we nee to get the duplicte lines out and add them.  That is the next part of the query we are working on.
Reply
  • Thank you.
    ncp.RUN,
    Count(*) AS PD
    , sbu.SBUPD
    to
    ncp.RUN,
    Count(*) AS PD
Children
No Data
