Differences in SWQL in EOC?
I'm the most interested in EOC to do unified reporting across different Orion instances.  I tend to fall back on the raw queries to get to the data I want and while the lack of inclusion of SQL along with SWQL is frustrating, I understand it from a design perspective.
What I've been struggling with is where the SWQL in EOC seems to function differently than the SWQL elsewhere.  For instance, I have a query for a report that runs fine in SWQL Studio, runs fine on an individual Orion instance and then does nothing except kick out "Query is not valid" on EOC.  The query is below and you'll note that there is only one custom property that definitely exists across my instances.  Everything else should be a function of SWQL that would work on both the individual Orions and EOC.
Futhermore, since EOC runs the SWQL against the other instances directly, there's not really a good way like SWQL Studio to run the query on the EOC and get some more pertinent error information.
I'd welcome any thoughts anyone can give.  I've tripped over a number of EOC SWQL items - this is just one obvious example.
select n.Caption, IP_Address,
TOSTRING(vm.VolumeSize/1024/1024/1024) + ' GB' as VirtualMemory,
TOSTRING (ram.VolumeSize/1024/1024) + ' MB' as RAM,
TOSTRING((vm.VolumeSize-ram.VolumeSize)/1024/1024) + ' MB' as PageFile,
TOSTRING(((vm.VolumeSize-ram.VolumeSize)-ram.VolumeSize)/1024/1024/1024) + ' GB' as PageFileDiff
from Orion.Nodes n
FULL JOIN (select NodeID, VolumeSize from Orion.Volumes
where VolumeType='Virtual Memory')
vm
on vm.NodeID=n.NodeID
where VolumeType='RAM')
ram
on ram.NodeID=n.NodeID
where n.CustomProperties.Department='Physician Services'
and MachineType like '%WINDOWS%'
and ((vm.VolumeSize-ram.VolumeSize)-ram.VolumeSize)/1024/1024/1024<1
order by ((vm.VolumeSize-ram.VolumeSize)-ram.VolumeSize)/1024/1024/1024
Parents
  • There also appears to be an error(?) where two values with the same column name cannot be selected, even if they are renamed:
    select NodeID, v.Node.Caption, VolumeID, v.Caption, VolumeType, VolumeSize
    from Orion.Volumes v
    This does not work on the EOC - it returns the last "caption" value twice.  However, this works correctly in the SWQL Studio.
Reply
Children
  • mwb​ I will have a look at your examples and check with the engineering team to see where we can fill in some of the gaps and perhaps make improvements.  Thank you for providing all the details you have so far.
  • mwb​ Here are a few suggestions:
    1) Avoid missing table aliases in select statement: "select NodeID, v.Node.Caption from Orion.Volumes v" would be rewritten to "select v.NodeID, v.Node.Caption from Orion.Volumes v"
    2) Avoid duplicated column names in select statement: "select v.Node.Caption, v.Caption from Orion.Volumes v" would be rewritten to  "select v.Node.Caption as NodeCaption, v.Caption as VolumeCaption from Orion.Volumes v"
    3) To avoid data duplication when an entity with the same ID is present in multiple remote Orion Instances (Orion Sites), always use InstanceSiteId in JOIN statements. To explain, here is a simplified version of one your provided queries:
    select n.Caption, TOSTRING (ram.VolumeSize/1024/1024/1024) + ' GB' as RAM,  ram.VolumeType as RAMT
    from Orion.Nodes n
    JOIN (select NodeID, VolumeSize, VolumeType from Orion.Volumes where VolumeType='RAM') ram
    where n.MachineType like '%WINDOWS%'
    When executing it over a single instance of Orion Site, it returns a correct result. But when executing the query from EOC when multiple Orion Sites are attached to it, EOC will return duplicated data. To avoid that data duplication, add InstanceSiteId into select statement of inner query (so that each Node is identified by both NodeID and InstaceSiteId) and ram.InstaceSiteId=n.InstaceSiteId condition to JOIN statement to avoid cross-site joins.
    Another improvement to distinguish from which Orion Site data comes from, would be adding Site Name (n.OrionSite.Name) to the outer select statement.
    The complete query would look as follows:
    select n.Caption, TOSTRING (ram.VolumeSize/1024/1024/1024) + ' GB' as RAM,  ram.VolumeType as RAMT, n.OrionSite.Name as OrionName
    from Orion.Nodes n
    JOIN (select NodeID, InstanceSiteId, VolumeSize, VolumeType from Orion.Volumes where VolumeType='RAM') ram
    on ram.NodeID=n.NodeID and ram.InstanceSiteId=n.InstanceSiteId
  • "2) Avoid duplicated column names in select statement: "select v.Node.Caption, v.Caption from Orion.Volumes v" would be rewritten to  "select v.Node.Caption as NodeCaption, v.Caption as VolumeCaption from Orion.Volumes v"
    - well I'll be damned.  I swear that I labeled in the select statement and still ended up with a mess.  I'll go at this again and update.
  • Also this is a puritanical to censor "d---ed".
