Documentation/Templates
Hi there,
I am looking at finding what is the best "simple" way to structure work and especially work/changes brought across a network. A simple way to provide:
1) plan structure project/tasks to be completed
2) reporting documentation of reverse engineering/problems/solutions advised or applied
3) technical documentation of network/topology/switches/routers/vlans/firewall configurations for technical records and support
Be it building a new system, but even better when bringing changes in to an existent system when a lot of reverse engineer was needed as system underwent a lot of changes in the last 5 years but nobody documented anything.
Would be great of you could recommend template/links/ideas
- Situation analysis of problems/risks > solutions offered, potentially in multiple steps
- Reverse engineering approach/findings/methods/troubleshooting/analysis/corrective actions-solutions
- Documenting per subgroups (WAN/LAN/WLAN/DEVICES/CLIENTS/LOGIC) the work/tasks completed
Thank you so much for any suggestions!
