How to connect to DPA API using Javascript Fetch
Version DPA 2022.2.7862
Attempting to use Javascript to connect to DPA using API Call. Keep getting error TypeError: Failed to fetch
Connection String is:
var rToken = '---------------------------------------------------------------------------------------------------------------------------------';
fetch('https://*************:****/iwc/api/security/oauth/token', {
method: 'POST',
body: 'grant_type=refresh_token&refresh_token='+rToken,
headers: {
}).then(function (resp) {
prompt(resp.statusTest);
}).then(function (data) {
prompt(data.data);
}).catch(function (err) {
prompt(err);
I am able to use PowerShell successfully using these parameters, but the HTML page throws an error when JavaScript is used
  • This seems like you're working on something awesome. Would love to see some of the PS if it's available, i've struggled with this in the past but havnt tried recently.
    Offhand i'm not seeing a fix yet, but I might need to work in this space fairly soon
