How to SUM personal composite metrics in APPOPTICS?
Hi All,
I've created 3 personal composite metrics in APPOPTICS, but I want SUM these 3 personal composite metrics to show in a Big Number Graph, but when I applied my new SUM composite metric appear in the graph this message: "There is no data available at this time interval".
Could someone can help me here?
I'm a noob here in APPOPTICS.
Follow the Details at below:
SUM Composite metric:
sum([
s("composite_truevue-prod-enterprise01.error_rate",{}),
s("composite_truevue-prod-report01.error_rate",{}),
s("composite_truevue-prod-report02.error_rate",{})])
Personal Composite metrics:
composite_truevue-prod-enterprise01.error_rate:
scale(
    divide([
        zero_fill(sum(s("trace.service.transaction.errors", {"service": "truevue-prod-enterprise01"}, {"period":"60"}))),
        sum(s("trace.service.transaction.requests", {"service": "truevue-prod-enterprise01"}))
    {factor:"100"}
composite_truevue-prod-report01.error_rate:
scale(
    divide([
        zero_fill(sum(s("trace.service.transaction.errors", {"service": "truevue-prod-report01"}, {"period":"60"}))),
        sum(s("trace.service.transaction.requests", {"service": "truevue-prod-report01"}))
    {factor:"100"}
composite_truevue-prod-report02.error_rate:
scale(
    divide([
        zero_fill(sum(s("trace.service.transaction.errors", {"service": "truevue-prod-report02"}, {"period":"60"}))),
        sum(s("trace.service.transaction.requests", {"service": "truevue-prod-report02"}))
    {factor:"100"}
 Thx in advance, regards.
  • Hi,
    The answer for your question is simple (unfortunately) - composite metrics cannot be nested. To achieve currently what you need would require creation of the composite metric like this:
    sum([
    scale(
        divide([
        {factor:"100"}
    scale(
        divide([
        {factor:"100"}
    scale(
        divide([
        {factor:"100"}
    I hope that will help.
  • Hi,
    It's helped a lot!
    Many thanks, it's solved my problem here.
