[Tool]ARM Template Generator V2 - Updated 22/11/21
Hi everyone,
I am pleased to announce the availability of the second version of the ARM Template Generator Tool.
The documentation is now included in the download package.
What´s new?
- Interface redesign
- Darkmode
- Support for User Template Import
- Option for creating a User Template based on an existing Account
- Support for Group Template Creation & Import
- Support for Open Template Creation & Import
- Help links now open in Browser and have been updated
- Tooltips and watermarks throughout the tool
- GUI for building creation rules
- Added selection of premade validation rules
- Added REGEX cheat sheet
- Multiple values are now configurable for Exchange Database and Policy fields
- Script parameter fields make autocomplete suggestions based on configured properties
- Added out of order navigation
Since i can only test so much on my own I would ask everyone using the Import feature to keep backups of the original template files or just not save over them, at least for now.
If you have any issues or see wonky behaviour please let me know, preferably with a detailed description of the expected and actual behaviour.
The old version will stay available under the old link for now.
Changelog 21/06/19:
- fixed an issue while importing templates with completely missing modules section
- fixed an issue with loading and writing the first parameter of the regexpr method
- fixed an issue with dragging list items into the builder UI when their index in the list is higher than the highest index that is displayed by default
Changelog 26/07/19:
- made sure the import function respects the order of AD Attributes (should have been the case before, if you see anything to the contrary let me know)
- added buttons for re-ordering AD Attributes
- fixed issue with the import and export function reading/writing the "IsScriptEnabledDefault" property in the scriptoptions as "IsScriptEnabledByDefault" (note that when you import a template with the faulty property name the value will have to be reconfigured manually)
Changelog 23/08/19:
- fixed a crash after editing lookuptables
- added minimum length field to password options - changed default value from 12 to 8
Changelog 25/03/21:
- added a check to ensure uniqueness of lookuptable names
Changelog 09/04/21:
-fixed crash when editing MultiValueTextField
-fixed issue with creationrules not automatically saving when using out of order navigation
-added newline variable token in creationrule builder (linebreaks in imported templates are parsed to type hardcoded text instead of the token)
Changelog 22/11/21:
-fixed nullpointer exception
-changed input validation on domain field to allow fqdns with digits in the tld
Download Link:
http://bit.ly/ARMtemplateV2
VirusTotal:
*note: the 1 detection is most likely a false positive, apart from an added catch clause and a change to a regex nothing changed from the last release (which had 0 detections)
Virus Total (new) / VirusTotal (Old)
Here´s a glimpse of the new interface:
pastedImage_2.pngpastedImage_3.pngpastedImage_4.pngpastedImage_5.pngpastedImage_6.pngpastedImage_8.png
  • Hi Adrian,
    normally on the web frontend it should be shown in the order which are in the template file. If that is not the case it is a bug. In the rich client you have mandatory fields, like samaccountname, givenname, surname and description where you can't change the order, but the LDAP properties itself should be the same as in the template file.
    When it is reordered by the TG then it would be great if Paul find time to fix it.
    kind regards,
    Mike
  • Hi Adrian,
    for OpenOrder Templates you can change the order by editing the Hierarchy (there should be a button there somewhere emoticons_happy.png).
    For all other templates currently you can not change the order in the Generator.
    I might add that in a future release but at the moment you will probably have to manually reorder them in the template.
    Regards
  • Hi Paul,
    nice tool, thanks.
    I got an Error whren editing lookup table entries. After pressing ok the program dies. Tested with the user-example and a self created template.
    Hope you have an idea.
    Edit: And the minimum password length for user creation schould be chooseable or 8 for me. emoticons_happy.png
    Regards
    Richard
  • Hi Richard,
    thanks for your feedback. I have fixed the crash and added the minimum length as editable field.
    Regards
    Paul
  • Hi Paul,
    great, it works. Solved in a fantastic reaction time.
    Thank you.
    Best regards
    Richard
  • Hi,
    I'm trying to get this to work, however I'm having some difficulty with the username creation. Our usernames are the first 3 letters of the surname and the first 3 letters of the first name.. so for example, if the user was James Dean, his username should be deajam. How do I set this in the template??
    At the moment its taking the first letter of the firstname. surname...
  • Hi bevan,
    this creationrule should work for your case:
    <toLowerCase>(<regExpr>('.{0,3}',{sn})<regExpr>('.{0,3'},{firstname}))
    it selects the first 0 to 3 characters of sn and firstname, the 0 to 3 part is important in case you have names that are less than 3 characters long.
    Regards
    Paul
  • Thanks Paul,
    That worked successfully!
    Last question, is it possible when creating the exchange mailbox as part of the template that it applies our corporate retention policy to the newly created  mailbox?
    I thought I could make use of the Exchange Scripting Agent, however it looks like its not being called when creating a user based off a template in ARM. Works when i manually create a mailbox in exchange though.
  • Hi Bevan,
    the way to do this is to use the script execution you can define in the template and set the retention policy in that script (for example via powershell: set-mailbox -retentionpolicy "policyname").
    Regards
    paul
  • Hi Paul,
    is there possibly a bug relating the Exchange Mailbox creation?
    When we try to toggle on Mapi and disable the toggle by the user, the checkbox in your template gen goes blank after reload.
    And is it possible to add a toggle for the Email Adress policy that you can toggle in Arm in the Email adress change window on the bottom?
    When we set the Home dir at the user creation with an template (or do it manually) the folder is not created.
    Is there an option we miss?
    Anyways, thanks for the amazing tool.
