Alert when 2 Player locations show a web transaction down
We are monitoring several websites from 2 Player locations.  If one player location is down it's most likely something with that player, if both players show down then it's the website, is there a way to configure the alert to only alert when both player locations are down for a web transaction?
Thank you.
  • Sure. Bear in mind that in Solarwinds terms, a "Transaction" entity is the combination of a Location and a Recording. So, you're asking about cases where you have one Recording in two Locations, and both of those Transactions are down.
    Here's how to do it:
    1. Create a new alert.
    2. For "I want to alert on", choose "Custom SWQL Alert (Advanced)".
    3. For "Set up your SWQL condition", choose "Transaction".
    4. You'll see the next field change to the beginning of a SWQL query:
      SELECT Transactions.Uri, Transactions.DisplayName FROM Orion.SEUM.Transactions AS Transactions
    5. In the field below that, add this:
      WHERE RecordingID IN
      SELECT RecordingId
      FROM Orion.SEUM.Transactions T
      WHERE Status = 2
      GROUP BY RecordingID, Status
      HAVING Count(RecordingID) >= 2
    6. Finish setting up your alert actions, etc.
    This part of the query finds all Recordings there are at least two instances of the recording (that is, two Transactions) and both instances have a status of 2 (Down):
    SELECT RecordingId
    WHERE Status = 2
    This part of the query finds all transactions that use that Recording:
    WHERE RecordingID IN ()
