Hello.
I am creating a mobile inventory app and I am using the API to retrieve Assets and make changes to some of the fields. All of them are working great except the room field. I am creating an asset.json file with all the parameters and within that, I have "room":{"id":1510,"type":"Room","roomName":"248"}. I have also tried it as just "room":{"id":1510) and I have tried it as simply "room":1510. Quite a few other iterations as well. The record updates, but the room remains null.
If I view an existing one using the api, the room shows up in the first format I listed above. But if I try to set the value, no joy. It is working fine for the other fields including the location field which I am formatting as "location":{"id":23} The room I am trying to save is a child of the selected location. It just won't save through the API.
Am I getting the format wrong? Is there something more to this that I'm not getting? Or does it just not work?
