Hi All,
Is Solarwinds SAM support monitor HP OpenVMS system process job? I have 1 customer using OpenVMS server and running batch file job. they using 1 single file to running multiple jobs. Currently, they want to use Solarwinds to monitor each of the job and alert them which of the job is stopped.
I had tried use the Solarwinds SAM out-of-box application template call "linux process check" to monitor each of the job but fail. The OpenVMS system is not a Linux OS.
Is anyone try on OpenVMS system before?
