Unmanaged Muted
I have a SWQL query that I have been using for a couple of years now, which I copied for THWACK.  It lists the devices that have been muted or unmanaged.  It does just what I need.  We have placed this on our home Summary page as widget.
Now comes my issue -
I has been asked to flag device as retired and unmanage them.  I need to filter on the "retired" flag.  Only show the device are Not Retired
NOTE This has been set up -->     NodesCustomProperties.AuditCategory Value  'Retired'
Where/how in the code would I add this statement? NodesCustomProperties.AuditCategory != 'Retired'
SELECT
N.Caption AS [Node],
ToString(N.UnManageFrom) AS [Suppressed From],
CASE
WHEN ToString(N.UnManageUntil)='Jan 1 9999 12:00AM' THEN ' - Forever - '
ELSE ToString(N.UnManageUntil)
END AS [Suppressed TO],
CONCAT('/NetPerfMon/Images/Vendors/',N.Icon) AS [_ICONFor_Node],
N.DetailsUrl AS [_LinkFor_Node],
--CONCAT('/Orion/images/StatusIcons/',N.StatusIcon) as Icon,
CONCAT(DayDiff(N.UnManageFrom,GetDate()), ' days') as [Suppressed days],
AE.AccountID AS [Supressed By],'Unmanaged' AS [Type]
FROM Orion.Nodes N
LEFT OUTER JOIN (
SELECT
AE.NetObjectID,
Max(AE.AuditEventID) as [AuditEventID],
Max(AE.TimeLoggedUtc) as [TimeLoggedUtc]
FROM Orion.AuditingEvents AE
where ActionTypeID in
SELECT ActionTypeID
FROM Orion.AuditingActionTypes
where
ActionType = 'Orion.AlertSuppressionAdded'
or ActionType = 'Orion.AlertSuppressionChanged'
group by AE.NetObjectID
) AS [LastMuteEvents] ON LastMuteEvents.NetObjectID=N.NodeID
LEFT OUTER JOIN Orion.AuditingEvents AE ON AE.AuditEventID=LastMuteEvents.AuditEventid
WHERE N.UnManaged=1
UNION
SELECT
ToString(Supp.SuppressFrom) AS [Suppressed From],
ISNULL(ToString(Supp.SuppressUntil),' - Forever - ') AS [Suppressed TO],
CONCAT(DayDiff(Supp.SuppressFrom,GetDate()), ' days') as [Suppressed days],
'Muted' AS [Type]
FROM Orion.Nodes N
INNER JOIN Orion.AlertSuppression Supp on Supp.EntityUri=N.Uri
LEFT OUTER JOIN (
SELECT
AE.NetObjectID,
SELECT ActionTypeID
where
Thank You for any help!
Steve
  • Give this a try. Commented with --PUT YOUR CUSTOM PROPERTY HERE
    SELECT
    CASE
    FROM Orion.Nodes N
    LEFT OUTER JOIN (
    SELECT
    AE.NetObjectID,
    SELECT ActionTypeID
    where
    WHERE N.UnManaged=1
    AND N.CustomProperties.AuditCategory != 'Retired'
    UNION
    SELECT
    'Muted' AS [Type]
    FROM Orion.Nodes N
    LEFT OUTER JOIN (
    SELECT
    AE.NetObjectID,
    SELECT ActionTypeID
    where
  • Thanks but did not work
    Orion.Nodes does not contain Custom Properties
    They are located in this table -
    Orion.NodesCustomProperties.AuditCategory
    I will keep digging
    Again thank you for the effort.
  • If I am understanding your question you just need the 'retired' nodes for custom property name AuditCategoryValue? This may work.
    Select IP_Address, Caption, NodeID, AuditCategoryValue FROM Orion.NodesCustomProperties cp INNER JOIN Orion.nodes nd on cp.NodeID = nd.NodeID
    Where AuditCategoryValue Like '%Retired%'
  • Yes that is correct but I would like to put this filter on the current report see above
    I do not want the "Retired" nodes to be listed in the report
  • Have you tried this? Do you get any error? I think this will work. You are correct that custom properties are not in orion.nodes BUT many tables are "pre-joined", meaning that you can actually write like suggested above. Jumping from one table to another on the same line.
  • SELECT [N].Caption AS [Node]
          , [N].CustomProperties.AuditCategory
          , ToString(N.UnManageFrom) AS [Suppressed From]
          , CASE
                WHEN ToString(N.UnManageUntil) = 'Jan  1 9999 12:00AM'
                END AS [Suppressed To]
          , CONCAT (
                , [N].Icon
                ) AS [_IconFor_Node]
          , [N].DetailsUrl AS [_LinkFor_Node]
          CONCAT (
                DayDiff(N.UnManageFrom, GetDate())
                , ' days'
                ) AS [Suppressed days]
          , AE.AccountID AS [Supressed By]
          , 'Unmanaged' AS [Type]
    FROM Orion.Nodes AS [N]
    LEFT OUTER JOIN (
          SELECT AE.NetObjectID
                , Max(AE.AuditEventID) AS [AuditEventID]
                , Max(AE.TimeLoggedUtc) AS [TimeLoggedUtc]
          FROM Orion.AuditingEvents AS [AE]
          WHERE ActionTypeID IN (
                      SELECT ActionTypeID
                      WHERE ActionType = 'Orion.AlertSuppressionAdded'
                            OR ActionType = 'Orion.AlertSuppressionChanged'
          GROUP BY AE.NetObjectID
          ON LastMuteEvents.NetObjectID = [N].NodeID
    LEFT OUTER JOIN Orion.AuditingEvents AS [AE]
          ON AE.AuditEventID = LastMuteEvents.AuditEventid
    WHERE [N].UnManaged = 1
          AND IsNull([N].CustomProperties.AuditCategory, '') NOT LIKE '%Retired%'
    UNION
                , ToString(Supp.SuppressFrom) AS [Suppressed From]
                , ISNULL(ToString(Supp.SuppressUntil), ' - Forever - ') AS [Suppressed TO]
                , CONCAT (
                      , [N].Icon
                CONCAT (
                      DayDiff(Supp.SuppressFrom, GetDate())
                      , ' days'
                , 'Muted' AS [Type]
                ON Supp.EntityUri = [N].Uri
          LEFT OUTER JOIN (
                            SELECT ActionTypeID
                            WHERE ActionType IN (
                                        , 'Orion.AlertSuppressionChanged'
          WHERE IsNull([N].CustomProperties.AuditCategory, '') NOT LIKE '%Retired%'
    This snippet works, but has a definite limitation: It doesn't look at Unmanaged/Muted Interfaces, Applications, Groups, or Volumes.  As long as you know this is for Nodes only, then you are good.
    The issue (previous) is that we are hitting the NULL isn't a [string] issue.  This was gotten around by forcibly casting the Custom Property value to an empty string.
  • I feel like this would be a nice "sidebar" element on a Modern Dashboard, but que sera sera. Smirk
  • It worked Thank You -
    This will help So much going forward with "retirement" of device from the environment!
    Thanks You Again
  • I tweaked it a little bit (to make the management of the Custom Properties easier to understand) and added it to the Custom Queries Content Exchange as Unmanaged & Muted Nodes (with a Node Custom Property Filter] - Custom Queries - The Orion Platform
