This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Uptime Report SQL query
Hello,
I am working on creating an uptime report on our systems.  Management would like the report to include totals in the report as well as notes.
I have a SQL query written that pulls this data and reports correctly.  When I put this query into Solarwinds, the query is not supported.  I am thinking this has something to do with the temp table I am creating.   How can I modify this query for Solarwinds to create the report?
here is the query
/* Gets average availability for the last 7 days */
SELECT  Nodes.Vendor AS Vendor, Nodes.Caption AS Node_Name, Nodes.MachineType AS Machine_Type, Nodes.Server_Class,
    AVG(ResponseTime.Availability) AS  Availability
INTO #UptimeReport
FROM Nodes INNER JOIN ResponseTime ON (Nodes.NodeID = ResponseTime.NodeID)
WHERE
    ( datetime >= DATEADD(DAY, -7, GETDATE()) AND datetime < GETDATE() )
    AND ((Nodes.Vendor NOT LIKE 'Cisco%')  AND (Nodes.Vendor NOT LIKE 'Compa%') AND (Nodes.Vendor NOT LIKE 'Dell%')
GROUP BY Nodes.Caption, Nodes.MachineType, Nodes.Vendor, Nodes.Server_Class
go
Select * from #UptimeReport
Order by Availability Desc
go
Select COUNT (*) as TOTAL from #UptimeReport
go
select count(*) as '100%' from #UptimeReport
where Availability >= 100
go
select COUNT(*) as '>=99.9%' from #UptimeReport
where Availability > 99.9 and Availability < 100
select COUNT(*) as '<=99.9-0%' from #UptimeReport
where Availability < 99.9
go
Select #UptimeReport.Node_Name, #UptimeReport.Availability, dbo.NodeNotes.Note
from #UptimeReport, dbo.NodeNotes, dbo.NodesData
Where #UptimeReport.Node_Name = dbo.NodesData.Caption
    and dbo.NodeNotes.NodeID = dbo.NodesData.NodeID
    and Availability < 99.9
order by Availability
go
drop table #UptimeReport
go
  • can you please assist with SWQL behind these KPI widgets?
  • I imported and edited the dashboard to get the SWQL. From the great KMSigma Importing/Exporting Modern Dashboards - Orion SDK - The Orion Platform - THWACK - SolarWinds Community
    SELECT COUNT(*) AS [100% Available]
    FROM (
    SELECT [Nodes].Caption
         , AVG([Nodes].ResponseTimeHistory.Availability) AS [Availability]
    FROM Orion.Nodes AS [Nodes]
    WHERE [Nodes].VendorInfo.Name = 'Windows' -- Put whatever filters here
    AND [Nodes].ResponseTimeHistory.DateTime BETWEEN GETDATE() - 7 AND GETDATE() -- this is where you define your time period
    GROUP BY [Nodes].Caption
    HAVING AVG([Nodes].ResponseTimeHistory.Availability) = 100
    SELECT COUNT(*) AS [99.9% Available]
    FROM (
    HAVING AVG([Nodes].ResponseTimeHistory.Availability) < 100
       AND AVG([Nodes].ResponseTimeHistory.Availability) >= 99.9
    SELECT COUNT(*) AS [99% Available]
    FROM (
    HAVING AVG([Nodes].ResponseTimeHistory.Availability) < 99.9
    SELECT COUNT(*) AS [95% Available]
    FROM (
       AND AVG([Nodes].ResponseTimeHistory.Availability) >= 95
    SELECT COUNT(*) AS [90% Available]
    FROM (
    HAVING AVG([Nodes].ResponseTimeHistory.Availability) < 95
       AND AVG([Nodes].ResponseTimeHistory.Availability) >= 90
    SELECT COUNT(*) AS [Sub 90% Available]
    FROM (
    HAVING AVG([Nodes].ResponseTimeHistory.Availability) < 90
  • Thanks Steven,  works like a champ
  • what would the query be to list the nodes that are 100% or 99% for example?
    Doesn't have to be a modern dashboard widget, could also be report or custom query widget.
  • Here is an example for listing the nodes that are between 99 and 99.9%. The second example from above. You just need to remove the Count section.
