SWQL CASE Function
i would like to display the severity of each alarm , i noticed that the value returned is a number and i'm working on a way to change the value into something else .
i tried the CASE function as shown belwon but i'm getting error in the syntax:
SELECT
OAH.AlertObjects.AlertConfigurations.DisplayName AS [Alert Name]
, OAH.AlertObjects.AlertConfigurations.AlertID AS [Alert ID]
, COUNT( AlertHistoryID ) AS [Last 30 Days]
, CASE
When AC.Severity=1 then 'Warning'
When AC.Severity=2 then  'Critical'
ELSE AC.Severity
end AS [ Criticité ]
FROM Orion.AlertHistory OAH
INNER JOIN Orion.AlertConfigurations as AC on AC.AlertID = OAH.AlertObjects.AlertConfigurations.AlertID
WHERE EventType = 0 and  oah.AlertObjects.AlertConfigurations.AlertID IN ('714','618','735','732','941','942')  AND  OAH.TimeStamp > GetUtcDate()-30
GROUP BY oah.AlertObjects.AlertConfigurations.AlertID
this CODE is working Fine without the CASE function.
Thanks for any help you can offer.
  • This is a bit of a brainmelter. Does the subquery return exactly 1 "cell". 1 row 1 column?
    If no, that's your problem. If so.. not sure offhand what the issue is. The error might help.
    This structure is very unfamiliar to me. I think i'd do something to try and join all the data together (maybe a jazzy right join to groups), then wrap that in a subquery to filter it down to the thing I needed. Perhaps that doesnt apply to your case, hard to tell and also you can usually do this stuff in a bunch of different ways, and mine isnt better just familiar.
  • YEs it does return one value.
    To me it seems like the nested SELECT is not supproted inside CASE function.
    i have tested this with a simple SELECT query with not luck:
    , CASE
        When AO.RealEntityType= 'Orion.Groups'  then  ( SELECT  N.CustomProperties.Type_Node
    FROM Orion.Nodes AS N Where N.IPAddress= '192.168.0.23' )
        ELSE AO.RelatedNodeCaption
    end AS [ TEST Value]
  • I think none of this is "supported" as such, but this query from earlier should prove it's possible
    select top 1 n.NodeID, CASE when n.nodeid = 3 then (select top 1 '1' as one from orion.nodes n) else 99 end as test from orion.nodes n
    Could you supply either a bit more of the code (with some blanked values) and/or the error?
  • If you want to try it without the inner joins here is what I tried, still can't get the Case part going though
    SELECT
    [AlertHistory].DisplayName AS [Alert Name],
    [AlertHistory].AlertObjects.AlertConfigurations.AlertID AS [Alert ID],
    [AlertHistory].AlertObjects.AlertConfigurations.Severity AS Sev,
    COUNT( [AlertHistory].AlertHistoryID ) AS [Last 30 Days]
    --CASE
    --When AlertHistory.AlertObjects.AlertConfigurations.Severity LIKE 'a' then 'Warning'
    --When AlertHistory.AlertObjects.AlertConfigurations.Severity LIKE 'b' then  'Critical'
    --ELSE AlertHistory.AlertObjects.AlertConfigurations.Severity
    --end AS [jjj]
    --INNER JOIN Orion.AlertConfigurations as AC on AC.AlertID = OAH.AlertObjects.AlertConfigurations.AlertID
    --WHERE EventType = 0 and  oah.AlertObjects.AlertConfigurations.AlertID IN ('714','618','735','732','941','942')  AND  OAH.TimeStamp > GetUtcDate()-30
    --GROUP BY AlertConfigurations.AlertID
  • I think if you use the like, you need to use the % so like ‘%a’ if there are characters before but not after or like ‘a%’ if there are no characters before but after or like ‘%a%’ if there are characters before and after
  • Got it working
    SELECT
    COUNT( [AlertHistory].AlertHistoryID ) AS [Last 30 Days],
    CASE
    When AlertHistory.AlertObjects.AlertConfigurations.Severity LIKE '1' then 'Warning'
    When AlertHistory.AlertObjects.AlertConfigurations.Severity LIKE '2' then  'Critical'
    ELSE ToString (AlertHistory.AlertObjects.AlertConfigurations.Severity)
    end AS [Result]
    --WHERE EventType = 0 and  [AlertHistory].AlertObjects.AlertConfigurations.AlertID AS [Alert ID] IN ('714','618','735','732','941','942')  --AND  OAH.TimeStamp > GetUtcDate()-30
    WHERE AlertHistory.TimeStamp > GetUtcDate()-30
    GROUP BY [AlertHistory].AlertObjects.AlertID
  • Got it working
    SELECT
    CASE
    end AS [Result]
