Trying to alert on Custom poller across 2 nodes when value difference between the 2 nodes are greater than x.
I am trying to use Trigger condition using "Custom SWQL Alert (Advanced)" with "Custome Table Poller Current Status"
SELECT CustomPollerStatusOnNodeTabular.Uri, CustomPollerStatusOnNodeTabular.DisplayName FROM Orion.NPM.CustomPollerStatusOnNodeTabular AS CustomPollerStatusOnNodeTabular
WHERE Uri LIKE '%XXXXXXXX%'
I am get the expected results with 2 entries with the poller values in "DisplayName" column.
Can i do something like Max(DisplayName) - Min(DisplayName) ?
If so how.
Or is there another query that will allow me to get the diff between the 2 polled values of the custom poller?
