This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
MACRO SQL ERROR - Incorrect syntax near the keyword 'AS'.
Trying to figure out what I'm doing wrong, or to change SQL coding to a join statement
Trying to get all the member of group components only that are in an alert state (non-up, not un-managemented. etc) to be listed in and email to the support team.
here my code but keep getting subject message., can some help me here.
${SQL: SELECT StatusName FROM SolarWindsOrion.dbo.StatusInfo WHERE statusid !=1 + '.' + char(10) AS [data()] FROM SolarWindsOrion.dbo.ContainerMemberSnapshots WHERE status != 0 AND status != 1 AND status != 9 AND status != 27 AND ContainerID = ${N=SwisEntity;M=ContainerID} FOR XML PATH('')}
  • I've added a Column name to the Select line and the end called 'COLN'  and the query works when I remove the statement of 'FOR XML PATH('')'. But the only returns only 1 component back.  When I add the "FOR XML PATH('')" statement I get the  MACRO SQL ERROR - No column name was specified for column 1 of '0tlouona_hdf'.  Error.
    Also in MSSMS the result look like this :
    So when in run this within SolarWinds it seems like it don't know what to do with the top line of the return, here my query
    SELECT (upper(M.FullName) + ' (' + [data()].StatusName + ')' + ', ') AS 'BR'
    FROM SolarWindsOrion.dbo.ContainerMemberSnapshots AS M
    INNER JOIN SolarWindsOrion.dbo.StatusInfo AS [data()] on M.[Status] = [data()].StatusId
    WHERE status != 0 AND status != 1 AND status != 9 AND status != 27 AND ContainerID = 1
    FOR XML PATH('')
    So when in run this within SolarWinds it seems like it don't know what to do with the top line of the return, here my query . yes the XML Path flattens the return  to 1 return line of data.
    FOR XML PATH('')
  • , just a shot in the dark but what if you aliased out the column as 'XML'? I'm not super confident it'll make a difference, but perhaps it might.
  • Howabout this? Removed subquery and aliased everything.
    ${SQL: SELECT m.FullName + ' (' + s.StatusName + ')' + ', ' AS Output1 FROM ContainerMemberSnapshots AS m INNER JOIN StatusInfo AS s ON m.Status = s.StatusId WHERE m.Status != 0 AND m.Status != 1 AND m.Status != 9 AND m.Status != 27 AND m.ContainerID = ${N=SwisEntity;M=ContainerID} FOR XML PATH('')}
  • Sorry for taking some time. Below query is now testes and works fine for me. The alert trigger object should be "Groups" for the group-id variable included in the query to be correct.
    Use below in a html formatted email and you will get each item on a separate row.
    ${SQL: SELECT REPLACE(Replace((SELECT(SELECT M.FullName + ' (' + S.StatusName + ')' +'</BR> ' FROM ContainerMemberSnapshots AS M INNER JOIN StatusInfo AS S on M.[Status]=S.StatusId WHERE status != 0 AND status != 1 AND status != 9 AND status != 27 AND ContainerID = ${N=SwisEntity;M=ContainerID} FOR XML PATH('') ) AS N	), '<', '<'), '>', '>') AS [Result]}
  • Hi there I tried the code in my Alert email notification and its doesn't list the data terrifically, its shows the "<br>"  the html line brake logic, but still list everything on one continuous line.
  • here an examples
    ABZYMCCM01 (Critical) </br> XYZAsccm20 (Warning) </br>
  • Did you send the alert email as "html" and not "plain text"?
